MFL
Jul 03, 2017Nomad II
You aren't giving enough actual info, as to the TV capability. It would depend on actual scaled loaded trailer wt. You also will run out of TV payload, before reaching the 9,200 lb towing number. Everything in the TV plus the trailer tongue weight, hitch weight, will count against your payload. Payload number is on the tire loading sticker on driver's door panel. It will likely be around 1,500 lbs.
Jerry
Jerry
