MitchF150
Sep 17, 2020Nomad
I'd say get the 3.55 if you plan to tow that size trailer.. With the 10 speed, you can still select the gears accordingly and when running empty, it'll be just fine...
I have 3.73's with the 6 speed and Eco and it's a great combo for everyday driving and towing a #7000 TT.
When towing, I keep it in 5th Keeps me around the 2200 rpm range and the boost lower than towing in 6th.
You will find that running an EcoBoost, you have Eco or Boost.. If you are in the Boost, you will suck the fuel and the engine will run hot...
Towing, you won't get any better mpg's with any gear ratio..
Empty, with my 3.73's going 70 mph, I'm at 2000 rpms and can get 19-20 mpg on the hwy.
I'd get the 3.55's if it was me.. :)
Good luck! Mitch
Good luck! Mitch
