valhalla360
Sep 22, 2020Navigator
wing_zealot wrote:
I think generally speaking people towing 10K regularly don't buy and F150 Ecoboost. For instance, I bought an Ecoboost because it is my daily driver. I use it 80%± as a daily driver and get great mpg every day doing so (leaps and bounds better then the F250 I got rid of); and yet, when I need it for towing, it's tow beast also (getting nearly the same mpg towing as my F250).
I agree. My point was I think the 10k rating is mostly marketing because Ford knows very few will push that limit while doing a lot of towing miles. If they do it once in a while mostly flat land towing, they will probably get away with it.
Most people towing a lot up near 10k will jump up to the 3/4 ton trucks.
For the 1 in a 10,000 who actually does tow heavy regularly with the ecoboost, it's such a small percentage that it really doesn't impact the reputation if they have issues as it's so rare.
If Ford really trusted the engine to regularly tow heavy like that, you would see them offer it in the 3/4 ton trucks because commercial operators would be salivating over the fuel saving of a 3/4 ton that can get even 17-18 mpg when not towing and yes, you do see a lot of them cruising around empty or with just a light load where boost would be negligible and MPG would be much better.
