Grit_dog
Oct 01, 2020Trailblazer
If you have an Eco, much less a max tow, you already have the 9.75” rear axle.
If it’s too soft, stiffen it up and it will then be the same as a HDPP.
Bit longer wheelbase will not make much difference, but any number of easy add one for the suspension and some LT tires if you’re near the top of your tires capacity will do the same for you.
And presume most thought you didn’t think it pulled hard enough, as that’s what the thread is about.
