jimh406
Jun 27, 2022Explorer III
artburg wrote:
I was asking because I wasn't too impressed with the welds and how loose the outter part fits into frame mounted section.
Loose is good once you have a bit of corrosion from salt etc. The tiedown and mounts are under spring tension as well. I had the steel ones for 8 1/2 years and have had the aluminum ones for 7 1/2 years. Both sets worked fine for me with my 4000+ TC.
As far as the welds go, they warranty all that they sell and have great customer service, so in the event something failed, they stand behind it.
But, they are the only option unless you want to build or have someone else build you a set.
