ticki2
Jun 28, 2022Explorer
You can also use an old style belly bar if it doesn’t interfere with anything under the frame like exhaust or drive shaft . Given you use the right size material they are very strong . The down side is they are always there sticking out . You can make them short and use removable inserts . Keep in mind that with either Torklift or belly bar you are more likely to rip out the attachment on the camper long before either of them fail .
