The 4.30:1 rear axle means the engine will be turning fast at all highway speeds. Probably will shift into 4th gear at around 40 MPH under light load.
Make sure that it has a engine coolant filter, if it already has one - all the better, and keep it clean! If none has been installed, expect the first to last only about 800 miles, the second 2,000 miles, and the third until fall.
You can install it in the heater hose line with a Napa kit #FIL 4019. The filter is FIL 4070. Some install a small ball valve at the inlet and outlet, so they can shut them off, change the filter, and turn it back on, with minimal loss of coolant.
I Put a coolant filter on my motorhome when it was new in 1997. I did not change the coolant until it was 10 years old, then replaced the new looking top and bottom coolant lines, as well as install new coolant at that time.
The problem with the 6L and 6.4L Fords is that the coolant would clog the oil cooler and exhaust gas cooler, then leak water into the engine, and require a $10,000+ repair bill. The coolant filter prevents both problems.
Have fun camping!
Fred.
