rjstractor
Nov 04, 2020Nomad
otrfun wrote:Groover wrote:Can higher tow ratings overcome basic physics (truck weight vs. trailer weight)---the ole tail-waggin-the-dog syndrome?
Ford 2021 towing guide
You can get the highest tow ratings with max payload package.
All of the F150 engines have received significant bumps in tow ratings.
The 2.7 is now up to 10,000lbs, the diesel is up to 12,100lbs and the 5.0 is up to 13,000lbs.
Maximum GCRW is 19,500lbs. If I recall correctly the maximum GCWR for a 1991 F350 was 18,500lbs. Things have really changed.
A 5,000 lb. F150 pulling 13k? Seriously?!
Since you specifically mentioned the physics of the weight difference between truck and trailer, what is the difference between an F150 towing 13K and an F350 towing 21K? The proportional weight difference is exactly the same.
