MargaretB wrote:
ScottG wrote:
My advice is to think for yourself, do research and buy what fits your needs - not just what somebody else buys.
I agree, and my question is part of that research. Asking people why they do or buy what they do or buy is more valuable than reading manufacturer's reports. Especially when the people I"m asking are experienced and knowledgeable.
While doing your research, you'll probably find all three make a decent towing vehicle. You'll also find, all three make various versions that may or may not handle what you want to tow.
Prime example is F150:
Depending on wheel base, drivetrain, cab configuration, etc, there are F150's with as little as 750 lbs of payload and 5000 lb tow capacity. This version is pretty much maxed out with a driver, one passenger, and a load of groceries. There are also F150's with payloads all the way up to 3100 lbs and 11,000 lbs tow capacity. Ford is not alone in building trucks this way.
Depending on what it is you want to tow, you'll need to research each truck, not just the general truck series. A blanket statement of "a half ton should pull it fine" is not true with any brand.
As far as "Why pick Ford?", that could be pricing, available options, brand loyalty, even political.
One of my brothers drives an F150, only because of the amount of taxpayer bailout money used by the other two. Nothing to do with its towing capabilities.
The other brother, drives an F250 because he has a truck camper and he has never driven anything but Fords.
Myself, I have owned a Dodge Dakota, Dodge Ram 1500, Toyota Tundra, Nissan Titan, 3500 series Chevrolet van, and now an F250. At the time I bought the F250, Ford was the only one with integrated brake control. I did look at 2500 series Ram. I was not pleased with my heavy duty Chevy van, thus, I did not consider a GM product.
I don't konw what the next one will be.
