Wow sorry guys, I'm not online too often...
To all other V10 owners, thanks for the input. This should give everyone a good idea what to expect from this towing beast.
jerem0621 wrote:
Your numbers towing are accurate based on my experience as well. My truck was a dually and empty got around 9 -10 ish basically no matter what I did. If I could get 12-14 like you empty I would have been ecstatic.
Since you mentioned the 8.1 your buddy had.. may I ask what the MPG for your friend was? I have been considering an 8.1 in a Suburban recently. I suspect that the MPG's between the V10 and the 8.1 are relatively comparable. But I am not sure.
Thanks!
Jeremiah
We stopped comparing long ago, towing it's a wash but I'm clearly better on fuel when empty.fla-gypsy wrote:
Your towing mileage seems accurate considering it is a 5th wheel. The wind resistance makes a huge difference. I get a little better with my TT but your combined figure is within 2/10ths of mine. Kind of hard to compare to others unless it was a straight apples to apples comparison with height and weight.
Yes I agree. We have the same truck, I too have the 4.10 axle w/20" wheels.
