joerg68
May 19, 2022Nomad III
You want to pull a trailer behind a truck camper with a long overhang, using some sort of hitch extender, right?
You can always try and see what happens.
In order to calculate the necessary steering maneuvres, the algorithm probably needs to have an idea of the positions of the camera and the hitch point (and the trailer, via the sticker already mentioned) in relation to the vehicle axles and steering. Since these positions are constant on any given vehicle (with the exception of the trailer sticker), they may well be somehow included in the algorithm - either hardcoded, or as parameters. Or the assistant may just work with very broad assumptions, camera data and a self-learning approach.
If you change the camera and hitch positions without "telling" the assistant algorithm, it may produce results that do not match the actual physical reality. Or the way it is set up may prove to be fairly flexible and the results may still be useful.
There is no harm in trying under carefully supervised conditions ;-)
