esfd243
Oct 22, 2017Explorer
Ford/Chevy mileage
So I like the mileage our 2012 D/A gets with and without towing. We are looking at the Ford F350 with 3.55 rear end and wondering if the mileage is comparable or not.
FishOnOne wrote:Lynnmor wrote:Grit dog wrote:Lynnmor wrote:4x4ord wrote:
What you are saying is not true. I don't understand all of the difference between 3.55 and 3.31 gearing
That right there is the problem. I tried to help, but you would do well to read the manual before discrediting others.
You'd do well to think before typing as well.
In your previous post you alluded that the different gears were negated by different tire sizes! That would make no sense to offer different gearing then.
Plus you inferred that the rim diameter somehow affects rolling diameter. (Because rim size doesn't have a dang thing to do with gearing or mileage. )
There are no different injection cycles either.
More silly rvnet babble....
It is hard to believe that there are those that cannot understand that tires of a larger circumference coupled with gearing that is lower by the same percentage gives an end result that is the same. Childish remarks show an even greater lack of intelligence.
Well said....
