GDS-3950BH
Mar 26, 2021Explorer
Most TT floors if the sidewalls are laminated fiberglass and foam construction, have laminated foam construction floors and have been that way for at least 20+ years or more. Especially so for Forest River, Thor, etc. Some Forest River and other brands recently went to plywood floors such as Rockwood but in actuality its not plywood but OSB. The cure may be worse than the disease.
Some laminated floors last, some don't. Some are bad from the day they are laminated, some go bad from traffic from obese owners or constant use usually at high traffic areas such as in front of the sink and inside the entry door.
That's why almost every RV manual ever printed says it's designed for part time use.
Basically shoddy constructed junk almost across the board.
