- Ncm86ExplorerThank you, that helps a lot
PUCampin wrote:
Ncm86 wrote:
So a f250 would be better, would the engine size matter? 5.4 or bigger?
The reason I was leaning towards an f150 is that I was looking at only towing 3-4 times a yr. Have a wife and 3 small kids but want to have some room for when they get older
Hi! First off welcome to RV.net!!
I was originally going to reply that with that trailer you would be marginal but ok with the F-150 you mentioned, but with 3 kids it will not work. A growing family will add more weight both to the truck, and add more stuff to the trailer (look at my sig to see how I know this!! :))
F-150s come in many different configurations ranging in payload from under 1000lbs to over 3100lbs!! So no general statement can apply to all F-150s.
With stuff for a family of five, 2 batteries, propane, water, food etc. your TT may approach it's GVWR.
With 5 people, growing kids, and a 7600lb GVWR trailer, you need to be looking for a payload of at least 1800-1900. You DO NOT HAVE to get a F-250, there ARE F-150 with this much payload, and some with more. Look for a "max tow" equipped truck with a 7700lbs GVWR, or ideally look for one that has the "HD Payload" package (not just max tow) The HD payload F-150 has 2 easy markers, a GVWR of 8200lbs, and 7 lug wheels.
Good luck in your search! - JordanHExplorer III would check the dry weight on the trailer because the manufacture list my trailer as having a gvw of 7492 lbs, while its dry weight is only 4348 lbs. Thats a cargo capacity of 3144 lbs, I really cant see me having the cc this high. This may or may not be the case for you as well.
- PUCampinExplorer
I agree. If OP can tell us what TT they have in mind, maybe we can help a little more. Having over 3000lbs of cargo capacity in the trailer is the exception, it does happen, usually for the shortest trailer on the next size up frame and axles. With a 450lbs dry tongue weight, it may actually be the case. More often than not the trailer has a low cargo capacity and just adding normal stuff and water puts it at its max which is why most of us default to that position without more details.
I still feel they would be best served with a 7700lbs or 8200lbs GVWR F-150 which will have enough capacity to keep loading and towing from being too stressful. - TystevensExplorer
alexleblanc wrote:
PAThwacker wrote:
At campgrounds: 8 lugs rule all. I only see 1/2 ton crowd on this forum.
come to Canada, 1/2 ton's rule the campgrounds. Mostly because the cost of trucks is much higher here and people seem to tough it out with the 1/2 tons. I love my F250, but the F150 was a great matched tow vehicle with my previous TT.
I don't know where PAT camps -- maybe exclusively at RV resorts and such -- but at 'normal' state parks and such around here, there are lots of 1/2 ton trucks (or smaller) towing all sorts of trailers. I'm actually often surprised at the combos I see -- they would give some folks on here nightmares! And yet, some how, some way, they are at the GC having a good time!
As the OP has indicated, there is more to the equation than just finding the ideal tow vehicle. For many of us, our tow vehicle is used for far more than just towing. For our family, where towing is only 5-10% of the annual mileage and things like unloaded mpg, ride comfort, size and ease of maneuverability factor in, we decided we are fine "making due" with a 1/2 ton SUV for our relatively few and short camping trips. Sure, we don't have a ton of GVWR to spare and aren't winning races up the hills, but we are happy with our decision.
Good luck! - kaydeejayExplorer
downtheroad wrote:
Small correction if I may - payload numbers do NOT allow for a 150# driver, so the driver weight will be part of that 600#. I suspect the OP will max out that 7350# GVWR truck. The HD F150 (8200# GVWR) would be a better bet.
The dry hitch weight is meaningless.
Let's pretend that you fully load the trailer to it's 7600 lbs. Your hitch weight will be around 1000 lbs. That only leaves about 600 lbs of payload for everything except you in the truck...
Probably..hopefully you won't load your trailer to the max, but it does happen. I think you are probably ok with the towing end of it, but are going to be close, with very little margin on the PAYLOAD side of it all.
Good luck with it.
The confusion is that "Max Tow Ratings" DO include a 150# driver in the truck (but nothing else). - jerem0621Explorer III know I get blinders depending on my current vehicle.
I have a Sorento and a Town Car and I see these cars all the time. I can't tell you how many GMC Acadias I see because I don't notice them.
While our Sorento was getting repaired we had a minivan rental. I never realized how many minivans there were before driving that walrus around for two weeks.
I see a TON of 1/2 tons towing campers everyday on my commute. I also see a ton of 8 luggers too
OP. F150 will do a fine job. - BurbManExplorer IIWelcome to the forum! First off, I would suggest that you read the first post in this thread about some real world weights and experience towing a very similar sized trailer with a 150. Probably a good match, but how you load the truck/trailer and where you camp also figures into the equation. New member Idaho33 did a nice job on his write up and is worth the read.
- Brett_KExplorerThat is about the same specs as our Salem 26tbud. TV is a 2013 F150 SCREW with eboboost and max tow/max trailer. Payload is close to 1900 lbs.
- jaycocreekExplorer II
Ncm86 wrote:
I found a TT 26ft, 7600gvw and dry hitch 450lbs.not sure how big of a truck I need. i did find a 2011 f150 5.0 fx4 gcvw of 15,100lbs. GVW 7350 and payload 1560. With tow package. It is too small?
No, it's fine. I have a very similar trailer and truck and it does very well. A 2008 Ford F-150/300hp 5.4/3.73 . The trailer is 30ft tongue to bumper and weighs in just under 8k loaded.
My sons 2003 HD 2500/6.0 tows it no better and rides rougher and gets less gas milage.A trailer that size does not require a 3/4 ton truck when you have what you have. - Ncm86ExplorerI was looking at the wildwood x-lite 261BHXL. Dry hitch weight 434 and unloaded weight 4314lbs.
44,029 PostsLatest Activity: Jan 18, 2025
