campigloo wrote:
If it’s near the fridge check the little drain. It’s super flemsy tubing and can dry rot or get bugs in it. It should have some kind of direct route to the outside of the coach. Check it from the outside. It may even require removing the refrigerator.
Thanks campigloo, I will check that.
I checked the slide-out which is across from the area. I removed the couch and peeled back the carpet and the OSB is bone dry there.
So I am thinking, if it is from the roof that should rule out that side of the TT. I am hoping the damage does not go under the refrigerator area or the sink cabinet area. I really would hate to have to dismantle and remove those to replace the subfloor under there.
Or worse if the damage is in the bathroom. I cant imagine removing the sink, shower and toilet will be easy.
I am ordering a few rolls of the eternabond tape.
I already have a few tubes of lap sealant.
iso
