isonychia wrote:
westend wrote:
Meh, small spuds. I have been remodeling and into different spaces for years. Replacing a few panels of flooring and pulling the wet insulation is easy. I would assume that pulling the under belly covering is one of the remediation steps. You want to make sure that any floor framing and flooring sheets are dry. Just from your descriptions, maybe it's possible to cut the fabric at the wall joint where it is wrapped, save the material, and reinstall it when done. Since this RV is parked, you won't have to worry about road grime and water entering while you're working on it.
How you schedule the completion of your project is up to you but I'd give it some thought and see how and what you need to transport to make it all better than new. In my work truck, I haul a complete set of tools and various hardware/fasteners so my workshop travels with me. If you're short on tools to make the job go easy and fast, seek out a friend or guy that has them for loan. Maybe you can even talk him into helping. If I was closer...
Here are a few things I'd plan to do: Find where the water is coming from. Remove bad flooring sheets. Remove any wet or compacted insulation. Treat wet spaces in floor framing with bleach/water. Dry floor and framing with fans. Install foam board in place of spun fiberglass. Replace OSB with floor rated plywood. Inspect and tighten all plumbing bits.
I'd very much suggest to do the interior pressure test. For me, nothing would be worse than repairing a floor only to find that there are other leak entrances, undiscovered. If I had to rent a blower to do it, I would.
Good luck with the floor. It will go quickly, once you start.
Well I think I found the source of the leak.
The shower drain was leaking.
Now the problem is how to replace the drain.
I purchased a new drain but I cant reach the nut that compresses the seal to the underneath of the shower pan/drain hole.
This is a corner shower with a rectangular access panel. The problem is there is an elevated floor board that the shower pan sits on. That is in the way of accessing the nut. I can reach the nut but it's impossible to gain any leverage to turn it.
We tried a drain wrench, but the drain strainer was corroded and broke.
I looked under the trailer and of course there is no access panel in the underbelly.
Again, a totally idiotic design.
The only thing I can think of is to cut a piece out of the floor board the pan sits on to expose the nut or go under the trailer and cut an access panel out of the underbelly.
The shower pan is sitting on a few pieces of 2x4 with the "floorboard" on top. It's really 2 sheets of luan with foam in the middle.
Thing is, how did the manufacturer expect anyone to service it?
Am I missing anything?
iso
They were not built to be serviced. They are just slapped together as quickly as possible. You will have to figure out how to make your own service hole/
