Lynnmor wrote:
westend wrote:
You will need to gain access from underneath the trailer. Remove a section of belly covering, perform the repair, and reinstall covering. I'd bet you will find a bit of wet insulation and moldy framing from the leak.
I would probably go the opposite way. Pull the shower surround and base, then build it back up like it should have been. The shower floor is a marginal piece of junk and can be replaced this way.
I might go a third way. He says that he can see the problem but, there is a obstacle in his way to get leverage on it. I would probably take a hand saw and try to cut the obstacle out of the way and then after fixing the problem try to rebuild it somehow.
I will admit that my fixes usually work for me but, they do have a certain "Red Green Show" style to them. The only trouble I get into is when I sell something and the next person calls me up after and asks what the heck is going on.
