- goducks10Explorer
carringb wrote:
Outdoors / Northwoods are 4-season rated.
I've had mine down to -15F
It does use a lot of propane when dry-camping below +15F.
I don't think Lance is 4-season rated?
Lance has a 4 season option.
https://www.lancecamper.com/four-seasons/ - carringbExplorerOutdoors / Northwoods are 4-season rated.
I don't think Lance is 4-season rated? - valhalla360Navigator
jdc1 wrote:
None are true 4 season. When you get down to freezing temperature, they just don't cut it.
We've been down to -5F...that gets a little marginal but doable if you have a good supply of propane.
But down in the teens, no issues...even with a non-4 season unit.
Currently have a basic 25ft Gray Wolf and other than condensation on the windows (single pane) when it get's into the low 20's, it handled last winter fine. Usually a small 1500w space heater was enough to keep it warm. - SkibaneExplorer II
- dieseltruckdrivExplorer II
jdc1 wrote:
I have had two different Arctic Foxes at near zero F and they were fine. The newer one even had 35 plus mph winds at temps under 5 degrees F, and we were cozy and had running water. What else can you ask for? We are happy with our choice.
None are true 4 season. When you get down to freezing temperature, they just don't cut it. - dieseltruckdrivExplorer II
canoe on top wrote:
I had a previous 27-5L and now have a newer one, and both did fine with temps very near zero F. The newer one is actually better.
I had a Nash and now have an Arctic Fox. Have used both at temps a bit below zero with no problem. - downeastrExplorer
TurnThePage wrote:
Grand Design is definitely NOT 4 season. If you consider them satisfactory, then others like Cougar should be included too.
Arctic Fox, Nash, and Outdoors RVs all seem to perform pretty well in colder temps. I've read that Lance also does pretty well.
Units with slides lose a lot more heat.
If price is not a concern, some fiberglass clamshell trailers like Oliver and Bigfoot perform well too.
Thanks on the heads up on GD. We owned a Casita and thought Oliver was constructed similar: "ratfur rug glued to shell" not offering much R factor. I'll check out Bigfoot. - TurnThePageExplorerGrand Design is definitely NOT 4 season. If you consider them satisfactory, then others like Cougar should be included too.
If price is not a concern, some fiberglass clamshell trailers like Oliver and Bigfoot perform well too. - canoe_on_topExplorerI had a Nash and now have an Arctic Fox. Have used both at temps a bit below zero with no problem.
- jdc1Explorer IINone are true 4 season. When you get down to freezing temperature, they just don't cut it.
