JimK-NY
Jan 21, 2023Explorer II
You might have more load and less CCC than you think. I would weight the loaded rig and check the door sticker for the CCC.
I am not sure why you "probably could move the camper an inch or two forward". The camper should be loaded all the way forward and touching the front bed rail. Also be sure to load your gear to also help with a forward COG.
If you are within specs and your COG is acceptably forward of the rear axle, then some flexing on rough roads should not be a concern. A small amount of flexing on rough roads is normal when carrying a heavy load.
