notsobigjoe
Jan 24, 2023Nomad III
adamis wrote:
Got a question for you seasoned drivers with older rigs. I have a 1999 F350 Dually Quad Cab Long Bed. I've been driving it for thousands of miles and for the most part, it's been fine. However, while driving on rougher roads, I do get a porpoising effect happening. I can look in my rear view mirror and see the frame flexing at least an inch or two.
My camper is the Bigfoot 2500 and with everything loaded up is probably in the 4500lb to 5000lb range. According to the sticker on the camper the center of gravity is almost exactly over the rear wheels. Now the center of gravity does change with water in the tank as the fresh tank is in the front of the camper which puts it at the front of the bed.
The porpoising isn't a "problem" in the since that I am concerned about it causing damage. I'm well within the carrying capacity of the truck. That being said, it is an annoyance for comfort and drivability. I have already replaced the shocks on the truck and that has helped somewhat. I am also looking and seeing that I probably could move the camper another inch or two forward when I load it. I don't think this will make much of a difference though.
So, my next thought was to look at having my frame reinforced. I know there are all sorts of complications when going this route though. Ford does fully boxed frames for a reason because it gives so much more rigidity. I no there is at least one person that has done this on their 7.3 from a posting on the Ford forums. This is obviously a huge expense and extreme measure.
Has anyone else gone through this or found a way to handle excessive porpoising on older C channel frame trucks?
I drilled many holes into my truck frame over the years and was concerned if I changed the original weight rating. I went to a welder shop and the man said it was possible but unlikely given my truck was built in 1996. He said trucks are built differently these days and would have answered yes to my question if I had a late model truck. He filled the holes with welding material and welded a small plate over the spots at my request. I feel no difference what so ever. I hope this helps. My main problem was the front end was too light as the previous owner decide to cut away most of the steel for a custom hood. Again, I feel no differenc.
