adamis
Jan 24, 2023Nomad II
HMS Beagle wrote:adamis wrote:
That contrasts with the 1999 with Max Payload for the Crew Cab Dually Long Bed 2x4 appears to be 5355lbs and the 4x4 is 4910lbs.
https://www.xr793.com/wp-content/uploads/2016/10/1999-Ford-Super-Duty.pdf
So, with basically the same frame, how did they manage to get another 1500+ pounds of payload capacity out of it?
You should go by the Ford bodybuilders manual that I referenced, not by that brochure. The bodybuilders manual gives the specific configurations, in California - less, diesel engine - less. Because the empty truck weighs more. The bodybuilders manual does not give the diesel 4x2 DRW crewcab, but does give the 6.8L, and the diesels are less by about 500 lbs in all models. You could just weigh the empty truck, the GVWR is 11,200 for all models of DRW pickups in those years.
The frame configuration and layout is nearly identical between 1999 and 2015, but the material may be thicker. That is also listed somewhere in the bodybuilders manuals, haven't bothered to look. You probably can't go from 11,200 to 14,000 without doing something.
Thanks HMS Beagle. I did some research on the frame differences and what I found was Ford did increase the thickness. From this discussion here:
https://www.powerstroke.org/threads/frame-differences.136669/
The frame differences are:
99-04 Crew Cab F-250-350 Pickup 156.2" WB, (6.87 x 2.36 x .240), 6.0
05-10 Crew Cab F-250-350 Pickup 156.2" WB, (6.87 x 2.36 x .264), 6.7
That would explain the payload capacity increase.
