Bedlam
Jan 24, 2023Moderator
adamis wrote:
Thanks HMS Beagle. I did some research on the frame differences and what I found was Ford did increase the thickness. From this discussion here:
https://www.powerstroke.org/threads/frame-differences.136669/
The frame differences are:
99-04 Crew Cab F-250-350 Pickup 156.2" WB, (6.87 x 2.36 x .240), 6.0
05-10 Crew Cab F-250-350 Pickup 156.2" WB, (6.87 x 2.36 x .264), 6.7
That would explain the payload capacity increase.
2005 brought a number changes to the Ford F-series. Not only was the frame thickened, the front suspension was switched to coil, the leafs and stabilizer bars were thicker and the rims were taller to clear larger brakes. I am not sure when 4r100 transmission was introduced, but the 5r110 came in with 6.0 PSD.
