JRscooby
Jan 27, 2023Explorer II
mkirsch wrote:
I'm betting facebook guy thought nothing of his 2" of flex too...
I have to wonder about box frames. For 1 thing, C channel is used in heavy trucks. If the C can't be stiff enough, and fit in required space, double the C.
Plus, if need to add a bracket to mount something, drill thru the vertical part, use bolt to fill hole, and torque tight with nut and flat washer. Loose very little strength unless big hole.
Box section, drill and tap. But you can only get threads for the thickness of 1 side of box. A bolt thru hole drilled in both sides, then nut on other side, can distort both sides, and both flanges. This would weaken the frame a bunch.
