wanderingbob
Mar 16, 2015Explorer II
Free oil change !
I got my free oil change on my 2014 Ram Cummins . Cost $326 . Three hundred dollars for two fuel filters . I guess I gotta check on do it yourself !
FishOnOne wrote:45Ricochet wrote:jus2shy wrote:
RAMs from 2013 onward have 2 fuel filters. A 10 micron fuel/water separator. Then a 5/3 micron (2 filtering elements) engine filter that also separates water. Probably the best OEM setup of all the trucks right now with 2 water filtering membranes and 2 WIF sensors. Just changed mine today as well. The filters are about 110 to 120 dollars for both in a kit.
I suppose Ram must have read Ricatic's problem child filter problem. :B
Sounds like a nice setup.
Nice try El Capitan...
Perhaps the real reason was to reduce the number of injectors failures including the ones on the 5.9 that lacked good filtration.
Let me know if you need to see the video again! :W
