wanderingbob's avatar
wanderingbob
Explorer II
Mar 16, 2015
Free oil change !
I got my free oil change on my 2014 Ram Cummins . Cost $326 .
Three hundred dollars for two fuel filters .
I guess I gotta check on do it yourself !
  • dieselfiltersonline.com I have a f350 6.7 and got the filter kit (fuel filter and water separator fuel filtert) 1 oil filter and a air filter all MotorCraft for $80.00 delivered to the house and did it myself.
  • RAMs from 2013 onward have 2 fuel filters. A 10 micron fuel/water separator. Then a 5/3 micron (2 filtering elements) engine filter that also separates water. Probably the best OEM setup of all the trucks right now with 2 water filtering membranes and 2 WIF sensors. Just changed mine today as well. The filters are about 110 to 120 dollars for both in a kit.
    $326 for changing both fuel filters is highway robbery. Without even trying, I changed both filters within 1 hour. That's about $100 bucks in labor shop time, but I'd expect a pro to beat my time well handily. However, I know that dealerships like to charge almost $100 per filter as I tried to see if my dealer would try to match the price I buy my filters at online. Apparently they don't want to maximize their business due to having enough suckers around locally that pay the outrageous prices.
    Geez and I thought the Ford 6.7L fuel filters were outrageous. They are less than $90 for the pair.
  • Fleetfilter.com. I order all of my oil, fuel, transmission and air filters there.
    Did you get kissed too???
  • That should be called robbery. Granted mine only has one fuel filter at 60.00, oil filter for 13.00, and 12 quarts of oil for 45.00. Total 118.00.
    Even if you are paying another 60.00 for a second fuel filter thats a total of 180.00. I just cant believe they charge that much.
    Oh yeah, like mentioned Genos is the way to go
