Community Alumni
Aug 18, 2017Not applicable
You don't need anything special to chock spread axle trailers. Just use regular chocks. That's what I use with my Freedom Express. Place regular chocks on both sides of the tire. Drive up on them slightly to make sure they're tight.
One more note. If you find a set of X-Chocks or similar products that fit, you should not depend on these as chocks. Tires contract as the temps get lower causing the X-Chock to loosen. This can allow the trailer to roll away. Always use a set of regular chocks to hold the trailer in place.
