Old-Biscuit
Jan 08, 2015Explorer III
FAQ DEF
Q. When will DEF freeze ? A. This 32.5% solution will begin to freeze at 12 deg F (-11 deg C). At 32.5%, both the urea and water will freeze at the same rate, ensuring that as it thaws, the fluid does not become diluted, or over concentrated. Unthawing will not cause harm to the product.
Q. How do I keep the DEF from freezing in the tank of a Truck? A. SCR systems are designed to provide heating for the DEF tank and supply lines. If DEF freezes when the vehicle is shut down, start up and normal operation of the vehicle will not be inhibited. The SCR heating system is designed to quickly return the DEF to liquid form.
ON EDIT:
Use of the word 'unthaw' in last sentence of first question is not my use.
To be 'unthaw' would mean 'freeze' because when something is 'thawed' to 'unthaw' would mean the opposite.
But in this case.........article is using it to mean 'returning to a liquid state'
Now a days..use a word enough it becomes 'acceptable' even when wrong and when it has no correct usage. Dumbing down of America!
ON EDIT:
44,056 PostsLatest Activity: May 04, 2014
