- alexleblancExplorerOrder is changed to 3.31's, if it's even a bit better on fuel and the towing is better then my 2017, i will be happy.
- 4x4ordExplorer III
alexleblanc wrote:
4x4ord wrote:
^^^ Going from a 2017 to a 2022 you're going to find your doppelgänger is not really a doppelgänger. The newer Powerstroke and 10 speed is incredible .... will your '22 have the 3.31 rear gears?
I ordered the 3.55 rear gears not knowing if i really needed them or not.
You might want to consider changing your order to 3.31 gears. My 2021 had 3.31 gears and I was very pleased with its fuel economy. My ‘22 has 3.31 gears as well but I can’t yet comment on its mileage. Unless someone is continually towing a 20,000 lb triple axle toy hauler 3.31 gears are a better choice than 3.55. With 3.31 gears there may be times that you are towing in high winds or up and down hills that you choose to lock out 1 or 2 gears but with a 16,000 lb trailer in tow 3.31 gears will actually out perform 3.55 gears on a 6 or 7% grade. First gear with the new Powerstroke/ten speed and a 3.31 final drive is capable of putting more torque to the rear axle than a 2017 F-450 can in first gear with 4.30 gears. - alexleblancExplorer
FishOnOne wrote:
I'm surprised to see ya'll use a German word up North.
I have have several German cars in my garage, need to keep up on the lingo i guess! - alexleblancExplorer
I ordered the 3.55 rear gears not knowing if i really needed them or not. - I'm surprised to see ya'll use a German word up North.
- 4x4ordExplorer III^^^ Going from a 2017 to a 2022 you're going to find your doppelgänger is not really a doppelgänger. The newer Powerstroke and 10 speed is incredible .... will your '22 have the 3.31 rear gears?
- alexleblancExplorerCongrats, my doppelgänger arrives in June, in Iconic silver.
- blofgrenExplorer
FishOnOne wrote:
blofgren wrote:
4x4ord wrote:
^^^:B
Good find; they are very tough to find around here.
Sniffing around the Ford dealer lot? :W
:B I used to quite regularly in the 7.3L days!
No, we are a 1 year wait for Super Duties at my work and we are a very good commercial customer. Most of the dealers 2022 allotments are already filled. - 4x4ordExplorer III^^^ Supposed to be sunny and 6 degrees C in mountains Saturday .... perfect for skiing.
- Cummins12V98Explorer III
FishOnOne wrote:
Looks too cold for me! :E
Same here.
