96Tony
Aug 04, 2018Explorer
Fresh tank mystery
My 19' Keystone Premier Bullet has two low-point water drains below the fresh water tank, a hot and a cold. In years past, after dry camping and while winterizing, I would remove the caps and the tank would drain by gravity.
Recently, however, I pulled off the cap and got...nothing. There was definitely water in the tank, and when I turned on the pump it shot water out of the drain like crazy. Shut the pump off...nothing. I pushed a zip-tie up the drain nipple, so there is no obstruction, as also evidenced by the good flow while the pump is on.
To rule out an air lock, I also removed the fill neck cap, and opened up some faucets, with no different results.
I'm pretty flummoxed by this, and wonder if anyone has any thoughts or suggestions. Thanks in advance!
