DesertMax's avatar
DesertMax
Fresh Water Pumps:
Hi Guys, anyone know the best places to buy rv water system pumps?
You may start a new thread, but do not change the contents of your original post. Edit okay, change the subject and deleting the original post is not okay. Members have commented on your original post and it is very rude to simply change the contents of the original topic.
Wayne
Moderator
  • Agreed. I used 2 sheets of 3/4" ply on my truck bed to lift it up and it was fine. The distance measured 45" from bottom of camper box to the plane of the cab roof so that puts it to around a couple of inches wiggle room..
    Just to be clear, I do not believe there is any safety concern outside of the above consideration to having a standard cab and a lot of nose overhang..!
  • The reference to being only for an e-cab or crew cab (super cab) likely is in reference to the long nose, due to the probability that it has a north-south bed configuration.
    The only problem I see putting that old of a camper on your truck is clearance between the bottom of the camper overhang and the truck cab roof.
