opnspaces
Feb 12, 2020Navigator III
ER Alaska wrote:
The problem is that when I pull on the valve I can see just a small amount of the tubing (the tubing is cut at an angle a bit, so I can just see a little part of the end of the tubing) and when I try to pull on the valve the end of the tubing gets hung up on the tank opening. If I could get the tubing through the opening I could then clamp onto it. Main question/uncertainty is what would be the consequences of having the tubing separate from the valve and the tubing stay in the tank. Thanks.
I would examine very carefully as the tubing makes no sense on a single wall tank. When you pulled the valve off the tank did water come out? My thought is that the tubing goes back into an inner tank of sorts, and the part that holds the actual valve is not water tight. Maybe try adding a tiny bit of water with the valve loose and see if it only comes out the tube.
