oldokie wrote:
Have you ever put a low point drain in the bottom of a polypropylene tank in order to drain all the water out? It seems that this may be difficult to do.
Only "difficult" if your trailer has an enclosed underbelly, otherwise it takes but minutes. This is my fresh water tank as the trailer was built ...
... but after adding a couple of metal braces to better support the tank and prevent it from sagging when filled with water ...
... I moved the pump's intake hose down to what originally was the drain port on the bottom of the tank so the pump has no difficulty at all drawing all water from the tank.
