SoundGuy wrote:
oldokie wrote:
soundguy
that is a nice job on the tank support and pump pickup. itlooks like your fittings a spin weled into the tank and i think that is about the only way to do it in these types of tanks. My underside is open and there is definitely no drain in the bottom of the tank. I thought maybe someone had come up with a different way of installing a drain but I guess not.
Actually it would be quite easy to add a bottom port to any fresh water holding tank using a self sealing fitting such as this from Specialty Recreation.
That is a unique looking fitting. I wonder how well it works? With the "O" ring, it should work great. It sure would make an easy fix to the problem.
