Cup_fan's avatar
Cup_fan
Fresh water tank fill issue
We just purchased a new Vibe travel trailer and took it out Labor day weekend for the first time. One issue that I discovered is with the fresh water tank fill. Every other rv that I have had, you would just stick the water hose in the opening, and when water came spewing out, you knew the tank was full. This camper has a connection that you screw the hose into just like the city water connection has. But the problem is, there is a check valve. Most state parks that we stay in don't have water hook-up, so if we needed to add water to the tank, we just poured it in through a funnel. The check valve in this rig prevents that because there is not enough pressure through a funnel to push the check valve open. I am curious to know if anyone else has this set up, and how you get water into the tank without a water spigot near by.
  • RoyB's avatar
    RoyB
    Explorer III
    What you are describing sounds like the standard city water connection. The one way valve is there to prevent the water pump when being used to squirt water out of the city water fill port.
    This is a typical water flow diagram for RV trailers.
    Look for a different location for a round screw-on fill cap.
    Mine looks like this
    It may behind a locked door like this photo
