Sam_Spade
Jul 20, 2016Explorer
BBrownCG17 wrote:
I have a new 2015 Heritage Glen 282rk, my fresh water tank is 52gal. cap. I can only get about 25 gal in it before I start having water come out the vent,
Are you using a "hose extension" that goes about 18 inches into the neck ?? Most are clear plastic tubing with their own shutoff valve to regulate the flow.
That helps a lot.
I can generally go full blast to about half full and then must throttle it down to half flow or less for another 15 minutes or so. I also suspect that my tank only really holds about 80 percent of it's advertised capacity......and splashes a little bit out of the vent when going down the road too.
While it's a common problem, if you continue to only get a 50 percent fill......see your dealer.
44,056 PostsLatest Activity: May 04, 2014
