hlhpa's avatar
hlhpa
fresh water tank leak
I have a new leak in fresh water tank. I have a 1988 Lance 780/11.3 camper, all the water leaked, out so I believe it is low in tank..
I have taken the top inspection cover off and can see the top of tank, but the tank takes up all the space and can not see past it.
there is a cover in the front, that does not have all the screws clearly visible.
So do I take the front cover off from inside the camper., or make and inspection hole in front of or below tank on out side of camper, Should I cut the camper open, to get to tank?
thanks for any help.
Found the leak, mice had eatten thru water drain line at bottom of tank. after hrs of looking and cutting hole on out side of camper. 3" plastic hose replaced and hole patched and no leaks.
Life is good.
