rbpru wrote:
I agree, I would expect the drain valve to be connected to the bottom of the tank.
It is handy to know its location.
It is a moot point though, as you are not going to change it.
It is where the manufacturer put it and I do not think they intend for you to only use a portion of it.
Good point, I assume they built it that way for a reason. So, with that being said, will I need to be concerned with adding similar weight closer to the hitch to regain balance? So far, I haven't had any issues with trailering; I thought the rear kitchen would be a pain to deal with, but all in all every trip has been smooth sailing.
