mike-s
Jan 15, 2017Explorer II
That pump does not have a simple check valve, it has a bypass valve. The manual describes it -
So, the valve may be working exactly as intended, but the city water pressure is high enough to open the bypass valve, filling the tank. Do you use a pressure regulator on the city water line? What pressure is it set at? It could also be leaking.
It's interesting that more people don't report similar problems - that's a common pump and common RV pressure regulators provide 40-50 PSI. So if the bypass begins opening at 40 PSI as stated, one would expect to see this happening a lot. I wonder how common it is for manufacturers to put check valves between the pump and tank. As mentioned earlier, that should fix the issue.
The by-pass is a spring loaded diaphragm that opens up allowing water from the discharge side back to the inlet side. The by-pass is set to begin opening at about 40 psi and creating full by-pass at about 62 psiThe manual describes how to adjust it.
