ktmrfs wrote:
Bobbo wrote:
My boondocking water kit. Throw the tote in the truck and go. Has everything except the hoses, that live in the TT anyway. The blue thing is the 45 gallon potable water bladder.
The pump, showing hose connections (both male), switch, and fuse. I have an SAE connector on there because I have an SAE supply on the trailer, and battery cables with an SAE connector. I can power the pump either way.
Neither large, nor heavy. To me, at least
the 45 gallon bladder is certainly a good solution if it's easy to fill at the campground, less space and easier to do than jugs, but Many campgrounds we go to the fresh water source (a) isn't really accesible with a truck with a bladder in it, and (b) no threads on the water spigot so you need a "water thief" and a LONG hose. So that' why we use the 7 gallon jugs.
This is also nearly exactly what I do. I got tired of the 6 1/2 gallon jugs. The one of the differences is my pump hoses fit in the tote also. The other difference is my hose fittings fit standard garden hoses, female in male out.
Edited to add: Also my water bladder is a 60 gallon version.
