mobeewan wrote:
I also took a spare pump and added garden hose connections.
Can someone point me towards the adapter I need to connect 'garden hose' to the inlet/outlet of the typical RV pump (sure flow or similar)?
Something like this? Anderson Metals 57480-1208 Brass Garden Hose Fitting, Connector, read ¾” Male GHT x ½” Female NPT
https://www.amazon.com/Anderson-Metals-Garden-Fitting-Connector/dp/B000FPAPM8/ref=sr_1_7?dchild=1&keywords=3%2F4+to+1%2F2+ght+plastic&qid=1629810635&s=industrial&sr=1-7
Since I have the (old, but working) pump still in my 'wet box' in teh trailer, may as well put the correct adapters on, cut up an old garden hose (one end syphon hose, one and to stick into the fresh water fill port) and run some 12V to the area.
