vtraudt wrote:
mobeewan wrote:
I also took a spare pump and added garden hose connections.
Can someone point me towards the adapter I need to connect 'garden hose' to the inlet/outlet of the typical RV pump (sure flow or similar)?
Something like this? Anderson Metals 57480-1208 Brass Garden Hose Fitting, Connector, read ¾” Male GHT x ½” Female NPT
https://www.amazon.com/Anderson-Metals-Garden-Fitting-Connector/dp/B000FPAPM8/ref=sr_1_7?dchild=1&keywords=3%2F4+to+1%2F2+ght+plastic&qid=1629810635&s=industrial&sr=1-7
Since I have the (old, but working) pump still in my 'wet box' in teh trailer, may as well put the correct adapters on, cut up an old garden hose (one end syphon hose, one and to stick into the fresh water fill port) and run some 12V to the area.
I used 2 of
these Shurflo adapters and 1 brass male garden hose adapter and 1 female garden hose adapter both with 1/2" NPT female threads on them.
The threads on a Sureflo pump are actually 1/2" NPT, but I preferred to be able to swivel the fittings if I needed to since you can loosen and tighten the Sureflo fittings by hand. I also didn't want to connect metal threads directly to the plastic threads on the pump in case I had to swap out the trailer pump if it went bad.
I also added a plastic male garden hose quick connects to the inlet and a female garden hose quick connect with built in ball valve to the outlet. I use plastic garden hose quick connects on all my garden hoses.
