vtraudt wrote:
Just received a 'fountain' pump (submerge style).
Will check today if I can get it through the LID of the 7 gal jug.
Has barb adapter for 1/2" (?) hose.
The pump BARELY (I ground off some edges) through the large lid, but then need to put the barbed adapter on the outlet and push the hose on. Doable, but a bit combersome.
Will look into 'plumbing' up teh pump inside and bring the 110V wire/plug and the hose (garden hose connection) to the outside (small hole for wired and larger hole for the garden hose connection).
Not sure if large blobs of silicon (inside as good as possible, plus from the outside) will seal AND hold. I think I have seen srew on conenctions for fresh water tanks, but nut sure how they work (and if they work with the really thin walled 8 gal roller jug I want to use).
Then tried my "spare" sureflow (self sucker supposedly). Bought adapter from home depot (plumbing expert) from sureflow thread (had pump with me) to garden hose. Screwed on a few threads, but then started to go crooked. NOT sure if they gave me the correct thread, but forced it on with teflon tape.
Turns out that pump is shot (have to suck water in only then will it pump; gravity alone NOT enough). Ordered repair kit for the pump, see if it works.
Benefit: short suction hose (garden hose connection), stuck through top of jug. existing fresh water hose (or another short 8 ft section) from pump into fresh water tank fill. Run 12V with connectors to near the fill and plug in the pump.
