Gene_Ginny
Nov 10, 2015Explorer
fallsrider wrote:Yes, I did make a homemade manometer and then forgot when/where I posted it. :h
Gene&Ginny, did you do a write up on this forum when this happened? I think I read it if you did. On Sunday morning while DW was still sleeping at the campground, I did a search. What I read was where you made a homemade manometer to find the low gas pressure......
As you said, start with cleaning the burner then tap the stack and if a lot of rust falls out it may need cleaning. Sometimes even a new regulator doesn't have the correct pressure. After I hooked up the manometer I also tried turning on all the stove burners and they looked fine and the manometer only dropped a tiny bit. (from 8 inches to about 7 3/4 inches.)
