IBcarguy
Apr 06, 2017Explorer
parcany wrote:
We have a Jayco with a fridge in the slide. Behind the fridge is a fan that comes on when the it reaches a certain temp. The fan runs and when the temp goes down the fan shuts off until the temp gets to a certain point then comes back on again.
This is exactly what you are hearing. On a refrig not in a slide out, there is a vent to the roof that lets out all the heat from the coils. On a slide out refrig, there is no roof vent so they install thermatically controlled fan (fans). Most are easily accessed from the outside upper vent cover and you can add air baffle kits (or make one) to improve air flow. Some have replaced the fans with 'quiet' fans.
