NHDad
Sep 03, 2016Explorer
Fridge on propane
When driving with fridge on propane do I need to have the main power breaker on to provide the 12v power from battery? Drawing a major blank. Had problems on the road last trip out.
BB_TX wrote:They are both. I have breakers, but there's no reason to shut any of them off
I never shut off any breakers in ours, traveling or not.
12 vdc is on fuses, not breakers.
NHDad wrote:The battery switch needs to be in the 'in-use' position.
NHDad wrote:
Actually, fridge is running on propane so why would battery drain so fast?
SoundGuy wrote:NHDad wrote:
My battery must be the issue then, thanks. Propane would not light consistently when traveling. New battery this year, never trouble in the past.
Are you confident your tow vehicle to trailer charge line is working? If not, the fridge alone will significantly draw down the battery if it's not being constantly recharged as you drive.
No. When not plugged into 120 vac shore power battery power is fed directly to the trailer's 12vdc system, including the fridge electronics. The 120 vac breakers have no bearing on this function.
