BarneyS
Aug 02, 2018Nomad
An easy test is to look at the light. If it is working when the trailer is not plugged in then you have an inverter and it is on. Things that are plugged into the wall outlets, the microwave, the air conditioner, and often the TV will not work unless you have an inverter or are plugged into the shore outlet.
The fridge, while not operating on 12v but running on propane, still requires 12v to operate for the control board.
Barney
Barney
