covered wagon wrote:
Butch, towing your Subaru..... did you have to go manual transmission? I know some you can't just put in neutral and expect to tow... is that right?
You are correct, the Subaru is a manual. I had to order it as everything on the lot was an auto and Subaru is not towable with the auto (or at least newer ones).
To tow all I have to do as getting the car ready to tow is put it in neutral and make sure the key is in ACC. Now if I had a different setup for lighting I could go ahead and turn the key off but leave the key in the ignition. If you pull the key out then it locks the steering wheel. I have a light bar that that plugs into a DC plug and the DC plugs in the car require that the ignition has to be at least turned to ACC to provide power.
