snowpeke's avatar
snowpeke
Front brakes
I did a brake job on my 2002 2500 Dmax. The back brakes on the right rear were down to metal to metal. Put on a new rotor and pads. Now to the front. There were a lot of pad left but changed them any way. Now for a test drive the back brakes were warm but the front were cold. How can I get them to work equally?
  • rhagfo's avatar
    rhagfo
    Explorer III
    Brake job, pads, rotors, did you replace or rebuild the calipers? I have never had a hard time rebuilding a caliper, bit have found issues, when rebuilding.
  • Sounds like the caliper is sticking and not releasing properly. Time for a new one.
  • The front brakes do most of the stopping. The fact that the backs were wore down and the fronts had a lot of pad left tells me they aren't working right. Could be several problems, don't know on newer models but could be master cylinder, proportioning valve... etc.
