trail-explorer
Aug 19, 2013Explorer II
Food for thought:
There's a variety of add on gauges (electronic style) that plug in to the OBDII port and will read actual temperature that the PCM is getting from the cooling system temp sensors. With one of these you can see "actual temp".
The stock gauge isn't extremely accurate. I can see variances of up to 20 degrees in actual temp, and the stock gauge barely moves.
Check out the Edge Insight.... that's the one I run.
