I have a 2018 GMC 3500 with a Boss snowplow mount. I welded in a receiver into the cross member of the plow mount. I then installed turn buckles back to each end of the cross member to existing holes in the cross member support brackets. I use it for a front mounted spare tire. lt is rock solid. Boss also makes an air dam to replace the stock one so no cutting was required and the receiver does not interfere with the plow. The truck side plow mounts consist of two side plates that bolt to the frame and the crossmember. Very heavy duty.
